Fresh water pressure
My fresh water pump cycles repeatedly when I am using water, any faucet or outlet on the boat. The flow slows to a trickle, the pump kicks in, flow is good, the pump cuts off, repeat, repeat, repeat. Frustrating to say the least. No problem when connected to fresh water source on the dock; problem only when using on board water supply. Is there a setting on the pump, or perhaps a filter that needs cleaning? Any suggestions, please. JG
I had the same problem. There is a filter screen right at the pump. Try cleaning that screen. This corrected the problem for me. Fierrless.
I'll give that a try, hope it works, will be the first simple one I've encountered, on a boat!
You can also add an accumulator tank to the system. This will help prevent surging.
I had the same problem someone replaced a piece of the solid pvc from tank to pump with flexable hose and the hose was kinked.Fixed kink in hose problem solved.
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 973 06-20-2026, 07:16 AM
  Water tank level sensors Final Pursuit 4 2,571 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,365 09-17-2025, 05:52 AM
Last Post: Splendor
  Water quick connect fittings Final Pursuit 2 1,900 07-30-2025, 03:18 PM
  2900 open - a/c water pump not running North000 2 1,833 06-22-2025, 02:18 PM
