ENGINE HATCH OPEN
I just purchased a 88 3300 open and am getting ready to change man,risers,hoses and rust removal from engines. Wondering what anyone has used or method to open hatch more thanks in advance.
My friend put in a gen last summer in his 31' '96. They disconnected the bolts to the Pistons connecting the hatch and I think removed the hatch motor to make room. They were able to shim the hatch open more to allow room too drop the gen into the rear of the compartment. Not sure if you have the same setup, Took some work but worked.
This would only work if you could remove the seats.
(06-26-2015, 06:55 AM)alcord Wrote: I just purchased a 88 3300 open and am getting ready to change man,risers,hoses and rust removal from engines. Wondering what anyone has used or method to open hatch more thanks in advance.
I don't know if it's the same set up but the owner of the 3100 open I just bought said when he was doing major engine work he'd remove the seats and disconnect the hatches from the arms to open them up more.
the 31 is miles different than the 33...The 31 is much easier to get at the mills...But seats have to come out either way.
If you do not have a forklift or overhead crane/winch, remove the seat modules and unbolt the electric deck ram and open the hatch all the way to 90 degrees (obviously tie secured in the open position for safety!). If you have a forklift or overhead crane, I'd remove the entire hatch (seats and all).
Good luck!
Agreed, unbolt ram and seats. The hinges will stop out and prevent full access. I have removed the hinges and removed the floor by hand a couple of times.
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 36 11 hours ago
Last Post: hmtrerice
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 222 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 586 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,227 05-22-2026, 06:41 PM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 681 05-12-2026, 10:18 AM
ENGINE HATCH OPEN00
