2006 Tiare Sovran 3600 how do I remove the steering wheel?
Somehow I think I bent (warped) the steeling wheel, and I would like to have it straightened.  I got the cap off, and then there is a nut, I got the nut off, but nothing.  I cant tell if there is a retaining ring, or snap clip or not that needs removed.  Someone suggested beating on the nut and it should pop lose.  So Before I try that, I thought I would ask, and see if there is something simpler.  TIA
(it is one of those pretty big (2'?) in diameter wheels with wood on the outside)
(01-23-2017, 02:18 PM)sluggo Wrote: [Only registered and activated users can see links Click here to register]
You put the center bolt (with the point) in the center of the bolt (that you removed the nut from), then adjust the grabbers around the stainless ring, then using a wrench turn the center bolt.
Basically like this:
(01-23-2017, 02:40 PM)efontana Wrote: [Only registered and activated users can see links Click here to register]
Thanks!  so to be clear you have the same boat??  TIA
(01-23-2017, 02:45 PM)sluggo Wrote: [Only registered and activated users can see links Click here to register]
Yep!
(01-23-2017, 02:49 PM)efontana Wrote: [Only registered and activated users can see links Click here to register]
Yep!Thanks again!  I'll stick it on there and try and not worry about the little thing I think is some sort of keyway.
(01-23-2017, 02:52 PM)sluggo Wrote: [Only registered and activated users can see links Click here to register]
The piece of metal, "the key" stays in the square groove in the shaft and wheel hub. I replaced my wheel with a new one, and the new wheel came with a new key. Make sure you don't drop and/or lose the key. It will come right out no problem with the puller.
  Tiara 52 Sovran Salon Keel Question Knot On Call 1 199 08-05-2026, 01:16 PM
Last Post: Splendor
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 225 07-28-2026, 06:28 AM
Last Post: Tiara45
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,533 02-23-2026, 11:01 AM
  Removing Wall Panel on other side of helm on Sovran 3500 no shocks 1 954 02-15-2026, 03:38 PM
  Keel bilge pump runs on 52 Sovran Salon during trips Knot On Call 9 2,472 08-21-2025, 08:28 PM
2006 Tiare Sovran 3600 how do I remove the steering wheel?00
