'87 27' open painting
Looking to paint the hardtop on new to me 1987 Tiara 2700 open. The hard top is not original and added by the previous owner. I'm replacing the electronics (radar, GPS, etc) and while I have all the hardware off the hard top want to put a coat of epoxy resin to smooth it out (fiberglass fibers starting to show) and paint it to match the hull. I've searched and found conflicting info. I've seen awlgrip oyster white h8139q but also found from Tiara gel coat colors called eggshell or ermine white or laguna sand. Awlgrip does offer an eggshell h8015q. I'm not sure exactly what color I need and if awlgrip paint options will match. Anyone every paint their older tiara instead of gel coat? I'd rather paint than gel coat. Thank you in advance.
Check out MiniCraft out of Florida.
www.minicraft.com
I got a repair kit to match the standard Tiara Erminie White and it matched almost perfect for my 98 31 Open.  If you can get the specifics for your hull from Tiara I'm sure that Minicraft can match it.  They also have all the accessories or tools to get the project done right.
I recently painted the hardtop on my 43 Open with Awlgrip and am really pleased with the result. Much easier to clean and looks way better than the old surface that was quickly oxidizing. To be quite honest I have never myself put down Gel coat so can't tell you what you would be up against. I believe gel is probably better to have down when it comes to repairs, something I don't worry too much about with a hardtop.
In terms of paint colors Tiara came back to me with a custom mix color ( Awlgrip Fresh White) for 1999 and newer boats for the window frames and arch (painted surfaces). Pre-1999 they recommended Awlgrip Oyster White which has a more yellow tint to it and probably closer to your hull color. Not sure about your gel color but if you do go the paint route then a call into Tiara might help you select a good match. Or get an Awlgrip paint card and use that as your baseline. On my 43 the arch color is slightly off from the hull/HT gel color so I used the paint card and got a very close match. If I can figure out how to attach a photo I will include
The other piece of knowledge I would pass on is to consider using Awlgrip's flattening agent. That paint is so reflective it will show every defect in your hardtop. The shine also won't  even remotely match the shine on your gel. I used 75% of the recommended flattening agent and it still put on a heavy shine. On my final coat I used the maximum amount and it ended up blending in perfectly. I ended up using the roll and tip method for this application.
Good luck
I definately prefer to paint over gel. I never worked with gel coat before and am looking for a quick fix.
Thanks for the info on flattening. I will definately add, especially being the hard top.
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 4 685 11-16-2026, 01:54 PM
  [Tiara Open] 36' Open interior lights Rick B 0 139 11-14-2026, 12:22 PM
Last Post: Rick B
  38 open bathroom recessed light bulb twilson0929 3 751 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 574 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 1,030 07-07-2026, 08:13 AM
