Tiara Open Unknown noise from Tiara 3800 Open engine room
There is an unknown noise coming from the engine room even while the engines are off. I am in Perth Western Australia and I have not been able to find a mechanic that can explain the source of the noise. I have taken a video which demonstrates the problem.
The noise seemsĀ to be coming from the seaside of the Starboard engine.
Link below for video
Can someone please suggest possible noise source.
Your video did not post. Try again and or describe the noise. someone may be able to help you.
I agree your posted video didn't post correctly.... I have a 2003 38 Open as well and on my boat there are several items that may be causing the noise. I have the Glendenning 50 amp shore power coiiler that has a motor that retrieves/feeds out the shore cable and there is a micro switche that shuts power to the motor off when fully retireved which may be stuck causing the motor to run even though the shore cable is fully retrieved. The 2nd is the holding tank pump that pumps overboard (through the bottom) anything in the holding tank (not sure if your boat has this pump). It's turned on via a switch under the steps..... My guess is the motor associated with the Glendenning cable retrieving micro switch causing the motor to run continually.... Just a guess as I don't have much to go on...
What's the noise?
Since the video isn't visible, first isolate whether it's 12V, 240V, or mechanical. With engines off, switch off shore power and battery switches one at a time. If the noise stops with shore power off, suspect the battery charger/inverter cooling fan or cablemaster. If it continues on batteries, check bilge pump float switches, shower sump, freshwater pump, or refrigeration compressor near the starboard engine space. A stuck automatic bilge pump or cycling fridge compressor can sound like it is coming from the seaside of the engine.
  Tiara 40 Express 2003 - Removal of Cleat saywhen 2 436 11-14-2026, 05:25 PM
  [Tiara Open] 36' Open interior lights Rick B 0 99 11-14-2026, 12:22 PM
  Looking for Help with Fuel Vent Issue - Tiara 2700 (1988) kahunamax 3 626 10-02-2026, 11:50 AM
  38 open bathroom recessed light bulb twilson0929 3 701 08-26-2026, 06:22 AM
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 430 08-21-2026, 02:33 PM
Last Post: hmtrerice
