Heater at the helm
We use our Tiara 3500 Express on the Chesapeake Bay and want to be comfortable in cooler/cold weather. We are considering adding a HeaterCraft  or Red Dot or equivalent heater at the helm area. These units are plumbed into the engine coolant and act the same as a car heater. We will be adding a drop curtain behind the helm seat so we are not trying to heat the great outdoors. Has anyone done such a job and where did you install the unit and vents?
I think that the best location might be under the helm area, although, under the helm seat might be an option.
Any ideas?
Have you considered installing a self-contained reverse cycle AC unit? That will give you both heat and AC. I installed a 16K Dometic under the helm seat in less than a day. Works great and really wasn't all that expensive.
(11-19-2017, 10:21 PM)jclark003 Wrote: Have you considered installing a self-contained reverse cycle AC unit? That will give you both heat and AC. I installed a 16K Dometic under the helm seat in less than a day. Works great and really wasn't all that expensive.
Can you share rough costs?
I had one installed under the helm seat of our 42 Open last year and including upgrading the raw water pump etc, it was roughly $5-6K...
My wife and I were just talking the other day about how it was worth every penny....
[-] The following 1 user Likes Maxwell's post:
bwoods94 (11-29-2017)
I installed the system myself which really wasnt that difficult. I want to say I paid about $2,500 for the Dometic 16K self-contained system, $150 for a pump trigger/relay (my existing pump had the capacity so didn't need an additional pump), and a few hundred on hoses, fittings, wire and a duct kit. Got it all installed in a day for about $3K-$3,500. I've spent a lot on upgrading my boat and this by far has been the best money spent. Wife couldn't agree more.
We use a small ceramic electric heater that sits on the floor beneath the helm. It plugs into a cockpit duplex. The drop curtain keeps the amount of space to be heated to a minimum. Does the job. When temps drop into the low 40's we sometimes turn the reverse cycle heat on down below and open the salon door. Helm area stays about 72 degree on a cold grey day in April when doing this. Heater costs about 90 bucks.
I installed a heatercraft unit under the forward end of the port l lounge on my 32 open. It is a grill faced unit so it mounted up off the floor of the storage area and a small 12 volt circ pump is mounted on the floor right next to it. These units work much better on a boat with raw water cooling as the water temps are much higher than a motor with closed cooling. Even so its a worthwhile addition, I plan on upgrading the blower motor for more air flow. I dont have a generator so this along with the drop curtain keeps the april fishing trips on lake michigan tolerable.
  Adding Helm AC DLydey 0 644 07-29-2025, 05:02 PM
Last Post: DLydey
  [Tiara Sovran] 4400 Sovran Air Conditioning Vent Grills in HELM area. Feetwet 0 1,113 06-08-2024, 10:22 AM
Last Post: Feetwet
  No cold air at helm giff1 4 3,053 08-20-2023, 10:09 PM
  Hot Water Heater for Tiara 2700 stanfarbman 0 1,056 06-07-2023, 11:15 PM
Last Post: stanfarbman
  03' 38 open helm air vent P/N? jmm 3 2,699 03-05-2023, 06:44 AM
Heater at the helm00
