2015 50' Coupe- location of AC strainers?
Hoping someone can help. Does my vessel have more than one AC strainer? I know of the one forward in the engine room (Which is clean), but are there others? I have one AC unit in the salon giving me the "HPF" error, while every other handler on board seems fine- thanks in advance.
Typically there is a strainer in betwen each ac water pump and thru-hull. Each pump typically supplies 1 or more condensers with a trigger to start the pump if either ac unit enters heat or cool mode. If you start all of you ac units and set the temperature way down so they all start cooling, then check your ER and bilge spaces. The pumps should be easy to locate as they will be humming away. Trace the feed water hose for each pump back to its strainer and you should be all set.
  HPF error and strainer location d5dekeyser 1 65 05-03-2024, 09:02 PM
  2018 38LS Black water tank location Scottbee 1 500 03-11-2024, 10:27 PM
Last Post: Scottbee
  96 Tiara 3500 Express A/C pump relay location John C 2 1,025 05-22-2022, 06:37 PM
Last Post: John C
  [Tiara Open] Location Of My Cabin Air Conditioner and Filter Dry Foot-Wet Foot 10 6,697 09-17-2021, 09:02 AM
Last Post: Misdirection
  [Tiara Open] 2002 38 Open AC Strainer location kmf4107 1 2,330 08-04-2018, 11:37 AM
2015 50' Coupe- location of AC strainers?00
