2900 Waste Tank
#11
Behind the engine. That should be the Y Valve. It should lead to the macerator pump or the deck plate.
Mark - Reely Nauti
#12
I can't say which valve to turn, I don't have your plumbing diagram. It should show in the owners manual. I have had a similar problem caused by the vent being plugged. You must let air in to the tank order to suck waste out. Use a dental pick to remove the fire screen in the vent. A powerful vacuum suction will actually collapse your waste tank if the vent is plugged.  Now that's a real mess.  That screen is only needed on fuel vents and corrodes up badly on waste tank vents.  I also removed the screen on my water tank vent. No more slow fills. While you are at it, clean your fuel tank screens for a faster fill without a blow back. I spray in WD40.  Vent maintenance should be on every body's to-do list. Bugs love to live there and plug them up.
When you unscrew your fill caps listen for a hiss. If you hear one you have a vent problem.
Capt. George
#13
(06-11-2015, 07:25 AM)Uhehner Wrote: I can't say which valve to turn, I don't have your plumbing diagram. It should show in the owners manual. I have had a similar problem caused by the vent being plugged. You must let air in to the tank order to suck waste out. Use a dental pick to remove the fire screen in the vent. A powerful vacuum suction will actually collapse your waste tank if the vent is plugged.  Now that's a real mess.  That screen is only needed on fuel vents and corrodes up badly on waste tank vents.  I also removed the screen on my water tank vent. No more slow fills. While you are at it, clean your fuel tank screens for a faster fill without a blow back. I spray in WD40.  Vent maintenance should be on every body's to-do list. Bugs love to live there and plug them up.
Capt. George
thanks guys,  Ill try the engine room  valve first
#14
[quote='ReelNauti' pid='4351' dateline='1433971190']
Be sure your Y-valve is set for overboard discharge, not deck, before activating the macerator switch.
I had a friend...... OK it was me who forgot to do (only one time) and it will suck-in the side of the holding tank several inches. Thank goodness I didn't burn-out the pump.
  1997 4000 Express - Holding Tank Replacement jennyJ 9 4,730 05-26-2026, 07:27 AM
Last Post: frank.koetter
  Water tank level sensors Final Pursuit 4 2,178 10-09-2025, 06:37 AM
  2900 open - a/c water pump not running North000 2 1,468 06-22-2025, 02:18 PM
  Holding tank collapsing fix giff1 5 2,964 10-18-2024, 06:00 AM
Last Post: egstasea
  2018 38LS Black water tank location Scottbee 1 1,708 03-11-2024, 10:27 PM
Last Post: Scottbee
2900 Waste Tank00
