Replacement of Hot water heater
#11
(04-09-2017, 04:53 PM)CaptBrett Wrote:
(04-09-2017, 07:22 AM)ReelMagic Wrote: Before I change the cal rod I would ensure you have 110v at the hot water heater itself.....Need to remove the cover where the electric wires go into. Another test is to reset the overtemp sensor located under the same cover... I've attached the manual for the heater.. Look at pages 4 & 5, especially page 4 step 8 on reseting the overtemp switch.
Following replacement of my hot water heater I tried to remove the cal-rod from the tank but was not successful. Believe the Aluminum tank corroded the threads... M2C
Thank you again.... so i have been told this water heater has a heating element ? Is that correct ?
I have water running thru it, flipped switch a number of times, to see if my volt gage would move, but nothing, so i guess its not getting power ? Thoughts ? This is a big help I appreciate your help
Here is another? For you... i am searching for a carpet for my helm area.... only have found one online vendor where you can make you own template ship to them they will make carpet for you.
Do you have a carpet? Thanks again
Capt. Brett M. Sause
USCG Master Licensed Captain
443.220.4339
#12
Yes.. The heating element is also called a cal-rod heater...Good idea WRT to turning on/off the circuit switch to see if the volt gauge moved.... A better test would be to use a multi-meter at the cal-rod (heating element) leads on the hot water heater itself to see if 110v is there. If it shows 110v then I agree the heating element (cal-rod) may need to be changed.. Make sure the red over-temp button hasn't tripped. Hard to tell just push it in the ensure its working correctly...
M2C
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 613 06-20-2026, 07:16 AM
  1997 4000 Express - Holding Tank Replacement jennyJ 9 4,389 05-26-2026, 07:27 AM
Last Post: frank.koetter
  Water tank level sensors Final Pursuit 4 2,080 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,039 09-17-2025, 05:52 AM
Last Post: Splendor
  Water quick connect fittings Final Pursuit 2 1,412 07-30-2025, 03:18 PM
Replacement of Hot water heater00
