Aft Deck Seating
#11
You can by 5/16- 18 knob screws at Grainger
https://www.grainger.com/category/hand-k...n1Z1z0o10j
#12
That's great information. I could not find a source. The original knobs looked exactly like the DAVIES model and were 1-1/4" diameter with a 5/16-18 female brass insert. They were 3/4 " high. Just add a 5/16-18 stainless rod cut to the desired length and put some Loc-tite on the threads going into the knob.  Capt.  George
#13
(02-22-2016, 07:18 AM)Uhehner Wrote: I sold all the knobs and threaded rods I had on eBay. Why not just go to ACE Hardware and purchase 5/16- 18 Stainless Hex Head bolts at what ever length you need? Add a flat washer and be done with it. Capt. George
I've got this same problem. Have the seats, don't have the hardware that bolts them down.  Was planning to just go to ace to get bolts and washers, and was thinking about just using wing nuts for "tool-free" on and off.  Only thing i was wondering...was the original installation "water tight?" Obviously it's not going to leak a ton of water but it certainly won't be water-tight with just a nut and bolt installation.
I'm not worried so much about water dripping down into the bilge - more in any moisture damage to the deck from the hole being constantly "wet."
#14
If you search on the web or eBay look for 6CXY8  or 3008BG. Both numbers will get you the knob.
On my 31 Open the deck was fitted with an aluminum block in the fiberglass that was drilled and tapped to 5/16-18. Unfortunately Tiara used a poor choice of aluminum that corroded big time and caused the fiberglass deck to bulge up.
If you drill into the deck you MUST seal the hole against water getting to the balsa core.
Capt. George
#15
(02-22-2016, 01:21 PM)Uhehner Wrote: If you search on the web or eBay look for 6CXY8  or 3008BG. Both numbers will get you the knob.
Capt. George
interesting...mine does show signs of "bulging" around those locations.  thanks for the heads-up.
#16
Did you find these seats. I have this exact set out of my 3100 open. Brand new. Upholstery and wood. Would consider selling as I do not use them... 607.426.5919 we are strictly a fishing boat.
Sent from my SM-G900V using Tapatalk
  Acrylic deck hatch lens giff1 2 1,568 03-10-2024, 12:42 AM
Last Post: HIGH SPIRTED
  deck cushions honest mark 2 1,847 07-24-2023, 06:16 PM
Last Post: honest mark
  deck lights honest mark 6 3,940 07-22-2023, 11:04 AM
  3300 Deck Removal Lucky Dog 33 11 9,582 12-29-2022, 05:30 PM
  Swim platform deck options d5dekeyser 0 1,344 08-16-2022, 09:39 AM
Last Post: d5dekeyser
How to Put Boat Picture On Left?
Yesterday 07:51 PM
» Replies: 5
WTB Tiara Coronet (1997-2007)
Last Post: JaviAirstream
Yesterday 05:50 PM
3900 stateroom door track replacement
Last Post: joshuawhite
Yesterday 04:52 PM
Cabin Laminate Repair- 3300 Open
Yesterday 03:49 PM
3500 Open deck lift piston
Yesterday 08:10 AM
» Replies: 4
