voltmeter 3100 open 2001
#11
Switchable only if you could replace the bulb, so, no they are not.
(04-25-2016, 01:53 PM)Silver Rush Wrote: Are these the VDO Vanguard ones that are switchable from red to green lighting?
Lauderdale Speedo DOES NOT repair, they replace the 'guts' with those of an old unit on hand -if they have one , which they do not.  Same with Nolan Speedo in Greensboro.  It is a simple repair for a tech which apparently no one wishes to do any more.
#12
You need to Google the vdo marine catalog and match them up then. My 1996 31 open had the VDO vanguard series with red and green LED back lighting no changeable bulb. I have a 3 position rocker switch for the dash red - off - green lighting from the factory. I have had little luck finding any for replacement. I had the port fuel gauge rebuilt last winter.
#13
I purchase replacement voltmeters for my 2003 Tiara Open from eGauges.com..... Part number: VDO 12 V Voltmeters (A2C53191766-S)... There almost an exact replacement for the original gauges. Believe they are the same as what you have in your boat.... Take a look....
#14
At VDO's recommendation I purchased these.  They require a different mounting bracket, wiring and plug.  Not exactly a snap in replacement.  Turns a snap in replacement into a refitting job.  Apparently 2001 was the last year they used the Vanguard line of gauges.  Thanks for the help, the hunt continues....
(04-20-2016, 02:00 PM)Silver Rush Wrote: [Only registered and activated users can see links Click here to register]
(04-26-2016, 05:12 AM)ReelMagic Wrote: I purchase replacement voltmeters for my 2003 Tiara Open from eGauges.com..... Part number: VDO 12 V Voltmeters (A2C53191766-S)... There almost an exact replacement for the original gauges. Believe they are the same as what you have in your boat.... Take a look....
#15
Won the lottery!  I found an electronic tech who agreed to look at the voltmeter.  Fixed it in 15 minutes.  Popped it back in, it works!  Life is again good.   Big Grin
  2001 Tiara Coronet Companionway Door Latch lnapolitan 1 1,515 06-22-2026, 12:41 PM
Last Post: BuckeyeKiter
  Engine hatch actuator from a 1988 3300 Open cp4000 0 1,250 11-27-2025, 03:15 PM
  [Tiara Open] 1998 3500 Open Companion L Lounge seat for sale acbrown2001@yahoo.com 0 935 11-15-2025, 03:45 PM
Last Post: acbrown2001@yahoo.com
  Custom Comforter 35 Open CptRob 1 1,166 11-15-2025, 03:22 PM
  4100 Open looking for a swim platform deerejon 6 2,142 09-09-2025, 06:15 AM
Last Post: bluetowski
voltmeter 3100 open 200100
