  • 1 Vote(s) - 5 Average
Fuel tank debris
#11
Do you know what the diameter of the fuel pick-ups are?  Did you say you used cork gasket material to re-seal the tank?
#12
I think it was around.835 as .840 is the standard for 1/2-14 pipe threads. I used 1/8 cork gasket material for the access panel but viton rubber would have worked as well and would probably hold up better long term.
#13
Do you know of any commercially available screen filters that would work on the fuel pickups? If not, I would be glad to pay you to have you make some up for me. If you made those, you are more talented than I am! Let me know if you are able to help. Thanks!
#14
I don't know of any that are commercially made I'll look a look. I can make a few to sell next time I have a chance, may take me a month or so. I'll pm you before I start anything.
    Goldenrod Stainless Steel Filter Strainer — 381 Micron Particles, 40 Mesh, Model# 470-15
Might be able to get this to work easier I'll look into it.
#15
Great job on those screens.  I'm curious how you did that joint.  Is it solder?  What kind of flux did you use with the stainless?   I'd like to make similar screens for one of my forklifts.  Rosin core or solid solder wire?
#16
You can purchase wire mesh that is already welded into a diameter with open ends. I used a laser welder to attach the screen to the stainless disc.
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 385 08-18-2026, 02:11 PM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 756 05-12-2026, 10:18 AM
  [Tiara Open] 93 3100 fuel tank sending unit. Joeboch348 1 555 02-18-2026, 09:15 PM
  Oil pressure gauge, tank indicators lenoah 8 2,237 10-31-2025, 11:15 AM
Last Post: lenoah
  Replacing fuel full hose 3100 Open Joeboch348 1 976 08-20-2025, 03:53 PM
Last Post: S4Survivor
Fuel tank debris51
