2001 3800 TIARA OPEN FOR SALE
Oh baby, here's a nice one.  Lovingly maintained with lots of recent upgrades including a brand new enclosure, an all new $27k Garmin electronics package, underwater lights, engine servicing (including aftercoolers, etc.), all on a low hour boat (790 hrs) with the reliable Cummins 8.3 450's and a very clean bill of health on the wet coring drama that has plagued a lot of Tiara's in this vintage (and newer).  Sad, but true.
Impeccably clean, "Molly Kayte" is a 2nd owner boat that has lived in the upper Chesapeake her whole life.  This is one not to be missed.  Do the math on any other 3800 in the price range and this one is all ready to go.  Seller loves this boat immensely, but has aspirations of going bigger, SOON.
SEE THIS BEAUTIFUL BOAT AT THE ANNAPOLIS
BROKERAGE SHOW, OCTOBER 11-14
https://www.yachtworld.com/boats/2001/Ti...7Ddl5NKg3m
Boat Name
Molly Kayte
Specs
Designer: Tiara Yachts
Warranty: 5 years
Hull Shape: Modified Vee
Dimensions
LOA: 40 ft 9 in
Beam: 14 ft 2 in
LWL: 32 ft 4 in
Length on Deck: 40 ft 9 in
Maximum Draft: 3 ft 6 in
Headroom: 6 ft 7 in
Deadrise: 18 ° at Transom
Dry Weight: 22500 lbs
Engines
Total Power: 900 HP
Engine 1:
Engine Brand: Cummins
Year Built: 2001
Engine Model: 6CTA 8.3
Engine Type: Inboard
Engine/Fuel Type: Diesel
Engine Hours: 832
Drive Type: Direct Drive
Engine Power: 450 HP
Engine 2:
Year Built: 2001
Engine Hours: 822
Cruising Speed: 30 mph
Maximum Speed: 35 mph
Tanks
Fresh Water Tanks: (110 Gallons)
Fuel Tanks: (411 Gallons)
Holding Tanks: (40 Gallons)
Accommodations
Number of single berths: 4
Number of heads: 1
Seating Capacity: 13
Manufacturer Provided Description
The 3800 Open has a shape and style that further defines the Tiara Open series. The custom curved windshield, sheer lines, reverse transom, and integrated bow pulpit all work together to create an elegant and functional yacht. The interior reflects the beauty found above deck - with an owner's stateroom with double pedestal berth; dual access full head (with separate shower); complete galley; and U-shaped dinette (convertible to double berth (lounge back also raises for pullman-style berth).
Cabin
The cabin of the 3800 Open is spacious and comfortable, featuring a double pedestal berth forward with plenty of storage below, hanging lockers, and hullside shelves. The head can be accessed from either the owner's stateroom or the salon. It has Corian countertops with sink, mirrored vanity, storage locker, and is a full fiberglass head with a separate shower stall including sliding door and sump pump. The U-shaped dinette with table and storage compartments below converts to a double berth and also has a pullman style berth. The galley is well thought-out and features Corian countertops, S.S. double sink with pressure water system, recessed two-burner electric cooktop, built-in coffee maker, microwave oven, and Subzero refrigerator/freezer. There is a lot of storage with 3 utensil drawers, under counter storage with Lazy Susan, and a bank of upper dish lockers.
35" LED HDTV
Electronics
All electronics except for Autopilot, new in 2017.
(2) Garmin 7612 XSV GPS
Network sounder with Side Vu, Traditional, and CHIRP Sonar
Garmin AIS
Sirius Weather
Sirius SAT radio
Garmin 424xHD2 (72 mile) open array radar
Garmin GMI Multi gauge
Simrad AP20 autopilot
Icom IC-M605 VHF with AIS
ACR Remote spotlight
KHV Trac Vison TV3 SAT TV, new 2018
Hull
The 3800 Open features a transferable 5 year limited warranty on the hull. It is constructed with a water barrier outer gelcoat layer and handlaid fiberglass with a special formulated resin. Wood and foam core stringers are vacuum sealed and encapsulated with handlaid fiberglass and integrated into the hull. The seacocks and all underwater thru-hull fittings are made of bronze, and a hullside exhaust system is used. The 3800 has six oval custom opening port lights with screens for great ventilation and natural light while below deck.
New cutlass bearings, June 2018
Prop Scan propellers, Black Dog props, June 2018
Cockpit
The cockpit on the 3800 Open can be outfitted for fishing, cruising, or both - depending on how you want to utilize the boat. Standard configuration includes an all fiberglass companion door shroud with molded-in navigation chart area and drink holders. The centerline acrylic sliding door features a convenient sliding screen as well. The helm is a “heads up” fiberglass tilt-away helm station with full flush mount electronics capabilities. There is an oversized helm seat forward with wet bar and aft-facing seat. To the starboard is a spacious curved lounge with storage and cooler. Aft of the curved lounge is a standard aft-facing seat - an optional bait and tackle prep station with circulating livewell can be added here for the fisherman. A fold-down cockpit lounge is also an option that fits neatly into a recessed area of the stylish reverse transom.
Deck
The 3800 Open deck also has a transferable 5 year limited warranty. Tiara’s custom diamond pattern non-skid is used on all deck and cockpit surfaces for sure, safe footing. The custom Tiara windshield is made of composite fiberglass that blends beautifully with the lines of the boat. This new method of windshield construction is revolutionary in the marine industry and is engineered to eliminate the corner pilasters. A center ventilating section with power actuator is great for airflow while idling and a helm air option is available for added comfort. The transition to the foredeck is easy with grab rails and a sturdy one-piece welded bow rail. Other features include three aluminum deck hatches with screens and privacy covers, flush forward anchor locker with overboard drain, and a fiberglass molded-in bow pulpit with standard S.S. roller assembly. An optional windlass is also available.
New enclosure, 2016
New helm deck carpet, 2018
Electrical
The electrical system on the 3800 Open features a custom 12V and 120V master distribution panel under the steps, and a amp meter, reverse polarity indicator on a monitoring panel.
One 240V 50 amp 65' shore power cord with adapter, with optional Glendinning cable recoiler makes handling and storage easy.
120V 30 amp shore power and cord.
All batteries, Gel Cell, new 2017.
Battery charger, new 2017
All cockpit and courtesy lights LED
LED Navigation lights
Lumitec Sea Blaze underwater lights
Lumitec LED Spreader lights
Engine room and mechanical
The 3800 Open is equipped with either Cummins 6CTA 8.3 or CAT 3208DITA diesel engines. The Cummins provide 450 h.p. per engine and the CAT’s are rated for 435 h.p. per engine. Both engines provide sufficient horsepower to provide a cruise speed above 30 mph. Standard mechanical features include a Teleflex hydraulic steering system with 22" destroyer wheel, bronze axe head rudders and struts, water cooled shaft logs, duel VDO engine instrumentation, fresh water cooling, Racor fuel filters, and more.
Attached Files Thumbnail(s)
Capt. Brett M. Sause
USCG Master Licensed Captain
443.220.4339
www.themarineminute.com
  FS: 2006 Tiara 3200 Open Volvo 370hp Diesels Priced for Quick sale $135K FIRM delliott00 1 3,755 08-15-2026, 05:46 AM
Last Post: samsliving
  Selling my 2008 Tiara 39 Sovran August Rush 0 1,772 05-29-2026, 06:07 AM
Last Post: August Rush
  [Tiara Open] Wanted: 3600 Open mikefransb 1 2,440 05-28-2026, 02:25 PM
Last Post: Reel Adventure
  [Tiara Open] WTB 38 Open Craigzen 0 1,339 04-13-2026, 09:51 AM
Last Post: Craigzen
  [Tiara Coronet] For Sale soon - 2014 Tiara 3100 Coronet - very Clean Buddyseattle 0 1,586 04-05-2026, 09:06 PM
Last Post: Buddyseattle
