Tiara Open vacuflush system
happy thanksgiving fellow Tiara family.
We did our 20th TDBR today Turkey Day boat ride....   vacuflush system stopped working.  can't find fuse ? or pump  can anyone help me please
'01 38 open
thanks
Capt. Brett M. Sause
USCG Master Licensed Captain
443.220.4339
www.themarineminute.com
The circuit breaker for the Vacuflush is located on the DC panel under the steps in the cabin.... The unit itself is located in the engine room under the froward center floor board (between the engines).. You will need to lift or remove the engine room access ladder..
And if the circuit is ok ? And still not flush, what are your thoughts??
Thanks sir
When you step on the Head peddle to flush do you hear a vacuum sound? If not (& you know 12 volts is going to the vacuflush system) I would take a look at the vacuum switch on the vacuflush itself as that starts the vacuum pump... See attached diagram. Its part #13... Only a guess as you didn't provide much on the problem.. Good luck. M2C
  39 Sovran VacuFlush Pump Access Euphoria38 6 3,105 07-26-2026, 10:26 AM
Last Post: Euphoria38
  [Tiara Sovran] Vacuflush Pump out procedure Donaldjames 2 2,555 06-21-2023, 12:00 PM
Last Post: Donaldjames
  [Tiara Open] 1994 Tiara 3100 Open - looking for model number of Vacuflush toilet Tgilbert 3 3,206 05-26-2022, 12:53 PM
Last Post: RMS
  Fresh water system leaking Coronet 2900. Anyone have a diagram of the system or how zane202@live.com 2 2,645 02-27-2022, 05:45 PM
Last Post: zane202@live.com
  What’s This Part?? (head system) MC1600 6 5,114 08-03-2021, 03:17 PM
Last Post: MC1600
