PSS Shaft Seal Replacement/Drive shaft removal
Hello everyone,
I recently purchased a 2000 Tiara 3500 Express with twin 8.3L Cummins and ZF 302 Transmissions. With that being said, we ran over a log causing the port PSS Seal to leak due to a fracture in the carbon. We have all the parts ready to go on, but we are in trouble working to get the driveshaft removed in order to replace the part. Mechanic has tried 10,000 LB of pressure along with heating it but still no budge. Are we missing a bolt or anything? Does anyone have any recommendations or a step by step removal for the ZF 302 v-driveshaft? Anything will help!
Thanks Tiara Team!! In need of this help!!
Can you send pic ?
I just had my seals replaced. My mechanic had to make a special socket to get shaft out from coupler.
Pain in the a**. I get it.
If you can't get help here try boatdiesel.com. I've seen this come up a few times there and a lot of good mechanics on that site.
Not clear where you are having problems. Is it removing the coupler from the shaft or separating the coupler from the transmission output flange?
You have to remove the coupler nut and washer and then mount a puller on the coupler which drives the shaft out of the coupler same taper setup as a prop. It takes alot of pressure the puller plate needs to be 5/8 or thicker steel to not bend! Then apply heat to the coupler with Mapp gas it will need to get very hot and melt the paint off usually.
  Tiara 40 Express 2003 - Removal of Cleat saywhen 2 380 11-14-2026, 05:25 PM
Last Post: saywhen
  [Tiara Open] Cockpit bolster removal Rick B 0 60 11-14-2026, 12:15 PM
Last Post: Rick B
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 481 07-25-2026, 09:15 AM
Last Post: roboh20
  2001 38’ Open interior table base removal twilson0929 3 939 07-07-2026, 08:13 AM
Today 08:10 AM
» Replies: 4
Oil Filter ?
Yesterday 04:23 PM
Yesterday 01:54 PM
» Replies: 4
Last Post: saywhen
11-14-2026 05:25 PM
3500 Sovran trimtabs
Last Post: drprunner
11-14-2026 03:44 PM
