Tiara Open Engine hatch stuck open - 2014 Tiara 36 open. Any ideas?
My engine hatch is stuck open. Was working fine and can’t find any faults. Ideas?
Check all breaker switch s
ISBIB
As noted above, check all of the breakers.
If necessary, get a volt meter, test for power at the switch and again at the motor. If you are getting power all the way to the motor, it might be bad. But I suspect the problem is somewhere upstream from there.
I would check the switch as well.Its a double pole double through switch. Had to change mine several years back
I have a 2000 35 open and here are couple of things I had to do.
1) Make sure the reed switch for the removable seat is operational. It is located under the L shaped seat and magnet which activates the switch, or deactivates, is located on the removable seat. Mine was not functioning correct and I twisted the wires together on the switch, all working.
2) the 35 open has two relays located behind the helm which activate the rams. Check wiring or more likely replace relays as they may be malfunctioning.
Of course, check all circuit breakers and activation switches before going this far but I was assuming that was already done.
[-] The following 1 user Likes trit21's post:
Best Team (05-02-2021)
(02-20-2021, 02:19 PM)trit21 Wrote: I have a 2000 35 open and here are couple of things I had to do.
Thanks, I think this will be very helpful.
  38 open bathroom recessed light bulb twilson0929 3 444 08-26-2026, 06:22 AM
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 273 08-21-2026, 02:33 PM
Last Post: hmtrerice
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 353 08-18-2026, 02:11 PM
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 476 08-17-2026, 05:31 PM
Last Post: Bford100
  2001 38’ Open interior table base removal twilson0929 3 713 07-07-2026, 08:13 AM
Engine hatch stuck open - 2014 Tiara 36 open. Any ideas?00
