Crusader 454 will not go over 2800 rpm
I have crusader 454 xl gas engines in my 1996 33 open. While out today my starboard engine would not go over 2800 rpms..
All gauges are reading fine.
Any thoughts?
Have you changed fuel filters recently?
(07-31-2021, 02:07 PM)Mydiamond Wrote: I have crusader 454 xl gas engines in my 1996 33 open. While out today my starboard engine would not go over 2800 rpms..
Any thoughts?
I will give it a try..
From other posts, here are some possible issues/things to try:
1.  Fuel Starvation Issue
a. Check fuel filters (not sure if the 454 has two filters or not, but the 7.4s and 8.1s have a pancake (UFO) shaped filter and a regular fuel filter.  The pancake one is a bit hidden and has a mesh screen.
b.  Clogged Fuel Pickup Tube - Do you have a single tank or duel tanks (e.g., one for each engine)?  If so, maybe clogged pickup tube on tank for starboard engine.  You may want to have the tank cleaned.
c.  Clogged Fuel Vent - unscrew the gas cap to see if that solves the problem - could be a clogged fuel vent limiting the draw of fuel from the tank to the engine.
2.  Electrical/Firing Issue
a.  Check the plugs - make sure plugs are clean.
b.  Check the wires - make sure wires are properly seated on plugs and coils.
c.  Check alternator system - make sure engine batteries have sufficient charge and alternator output is appropriate.
3.  Major Engine Issues
a.  cylinder/valve issues - hire a certified mechanic
My bet, without knowing more, is that it is fuel starvation.
Best of luck,
M1
Thank you.
I will let the thread know what I find.
Is there a check engine light on? The engine could be in a reduced RPM mode due to a sensor error.
No engine light, no alarms.
Starts right up.. runs great until starboard engine hits 2800 rpm.
Both engines share 1 gas tank
Running down the suggestions from prior posts on this thread.
Will let you know if I find something
Check the inside condition of the distributor cap, remove the fuel filler cap and run the boat to check vent tube clogs, look for loose spark plug wires . Always try the easy stuff first.
What is the maintenance history? If you've not done a tune up (plugs, wires, cap & rotar) recently, I'd start there. Don't just inspect, but just replace them.
have a 2001 w/ twin 454's. happened to me. was a collapsed fuel line. the lines
have an inner liner. it will be the line that is from the fuel pickup/sender to the
connection through the bulkhead.
good luck
  [Tiara Open] 2003, 3100 with Twin Crusader 8.1L MPI Gas Engines jmdegraff 2 1,487 06-16-2025, 08:07 AM
  1997 Crusader 454 XLi Service Manuals TiaraTom 4 4,978 01-16-2025, 08:59 AM
Last Post: dthelen40
  [Tiara Open] Crusader gas engine crank but no spark Mydiamond 1 2,801 10-18-2023, 04:32 AM
Last Post: czarcone
  Crusader 8.1 mpi surges at running speed Betterdays123 13 17,295 06-28-2023, 09:57 AM
Last Post: Phil Lane
  Crusader Mechanic Needed North Florida 904polarized 1 1,946 03-27-2023, 04:41 AM
Last Post: 904polarized
Yesterday 06:45 PM
» Replies: 5
Yesterday 05:45 PM
Yesterday 02:44 PM
» Replies: 8
Yesterday 02:43 PM
10-26-2026 08:09 PM
