I recently noticed a leak coming from the holding tank. After further observation, I can see the leak is in the middle at the bottom of the holding tank. Is there a way I can fix this without removing the tank?
09-19-2021, 08:47 PM
You might be able to cut an access hole in the top, get down in there and clean the bottom and weld or epoxy a plate over the defect. That is providing the leak isn’t where a baffle meets and providing you have access to the tank top and may only be a temporary fix. Good luck
06-06-2022, 02:16 PM
What model boat?
| 1997 4000 Express - Holding Tank Replacement | jennyJ | 9 | 4,731 |
05-26-2026, 07:27 AM Last Post: frank.koetter |
| Water tank level sensors | Final Pursuit | 4 | 2,179 |
10-09-2025, 06:37 AM Last Post: Final Pursuit |
| Holding tank collapsing fix | giff1 | 5 | 2,968 |
10-18-2024, 06:00 AM Last Post: egstasea |
| 2018 38LS Black water tank location | Scottbee | 1 | 1,709 |
03-11-2024, 10:27 PM Last Post: Scottbee |
| crack in mid bildge | honest mark | 3 | 2,769 |
01-27-2022, 02:21 PM Last Post: neto |
| 1 Guest(s) |
