No power to galley outlets of coffee maker
I have a new-to-me 2004 3600 Sovran.
I've noticed that there is no power to the galley outlets and coffee maker. I've verified the breaker is on, and everything else seems to have power.
As I'm new to the boat, I'm still learning how to diagnose all of these things. Is there something really obvious I should? I'd love some pointers on what to look for, where to look, and what I should be doing to try and track this down.
It's a steep learning curve so far and am loving it.
On my 2003 38 Open I have 2 breakers under the steps associated with the galley and the coffee maker... One just for the galley outlets (one duplex outlet above the refrigerator & a 2nd duplex outlet under the far right galley cabinet). A second breaker located under the steps is just for the coffee maker... Not sure what your problem is but I had 2 breakers go bad quite a few years back which I changed (the lugs on the back of the breakers came out of the breakers).
At the risk of stating the obvious have you checked all the outlets in the circuit for a tripped GFI? Not unusual for all the outlets downstream to loose power if a GFI is tripped.
Sans Peur (10-30-2021)
I would second the idea of seeing if a GFI is tripped on another plug. We had this on our Sovran 3900. The tripped plug was in the theatre room. Once reset others in galley worked again. Hope this easy fix may work for you.
All in favor of GFI say I - LOL
Thank you all for your responses. I'm new to this all so still learning. I'll be checking for tripped GFIs first thing tomorrow!
If you email Tiara customer support with your hull number they will send you the wiring schematic if available. May help you trace down what is in the circuit. Good luck
I wanted to follow up with the solution in case it helps others in the future. It was a bad GFI.
Thank you everyone for your suggestions and for pointing me in the right direction.
[-] The following 2 users Like Tantram's post:
Misdirection (11-07-2021), Sans Peur (11-08-2021)
(11-07-2021, 12:34 PM)Tantram Wrote: I wanted to follow up with the solution in case it helps others in the future. It was a bad GFI.
Glad you have it sorted and thank you for following up. Cheers
  1997 4000 express shore power issue Salty0ne 10 4,058 03-31-2025, 08:27 PM
  Fridge and freezer isotherm combo only work with shore power or genset Toyoda 2 2,907 07-26-2023, 03:55 PM
Last Post: Sapphire
  No power to dash Mydiamond 5 4,291 05-07-2023, 07:52 PM
  [Tiara Convertible] Light with No Power Question T.Roy 3 2,911 06-14-2022, 01:32 PM
Last Post: Misdirection
  No shore power to one side of AC panel wcish 3 3,204 05-01-2022, 05:05 PM
Last Post: eric_nelson
No power to galley outlets of coffee maker00
