Tiara Open electrical issue
on my 43 open,I have an issue with some 120 volt outlets do not work when the shore power is in the 120/30 amp supply cord to shore power.When plugged into the 50 amp 220 shore power they work,,,,is that supposed to be like that?
yes you should have power to all circuits in the AC panel. The 120/30 will provide power to everything in the boat but doesn’t provide enough amps to run everything at the same time. For starters I would check for tripped GFI’s. Also check the panel and see if the breaker for the outlets is not tripped and that the indicator light is lit.
Do you have 2 120v shore inputs? If so are you only using one of them? On an old boat I had if I used only one it cut out some of the electrical systems. Once both were connected everything would work.
(12-09-2021, 06:31 PM)dduca@comcast.net Wrote: on my 43 open,I have an issue with some 120 volt outlets do not work when the shore power is in the 120/30 amp supply cord to shore power.When plugged into the 50 amp 220 shore power they work,,,,is that supposed to be like that?
That is how it works on my boat , the way I understand it is there are two hots 120 volts 30 amps each and when you are using only one of the hots “Called Legs” you are only getting half of the power  . When you are at 50 amp 240 using both legs then you have full power to the boat.  I am not an electrician but this is my basic understanding of how it works. We own a 2009 Tiara Sovran .
  [Tiara Open] 2005 TIARA 2900 OPEN DC ELECTRICAL SCHEMATIC COPY HIGH SPIRTED 2 2,782 07-05-2025, 12:54 PM
Last Post: HIGH SPIRTED
  1997 4000 express shore power issue Salty0ne 10 4,054 03-31-2025, 08:27 PM
  Glendinnning cable reel issue OurHighLife 3 2,493 11-05-2022, 09:11 AM
  [Tiara Open] 2004 32 Open DC Electrical Panel fixkr 0 1,632 11-11-2021, 10:22 PM
Last Post: fixkr
  [Tiara Open] 2002 Tiara 38 open ground issue Sam-n-I 8 8,508 01-02-2021, 10:50 AM
Last Post: sjcrum
electrical issue00
