Dripless seal replacement. How much effort?
It looks like a have a leaky dripless shaft seal. What’s the level of effort replacing one of these bad boys? (Video of leak)
How often do seals go? Anything else I should look at before assuming a seal?
The good news is you have new seals on the shaft. I’ve never done it myself, but understand it’s a pretty simple process of:
- Remove the four screws on the black face plate.
- Pull the old seal back and cut it out.
- Slide new seal down the shaft and into place.
- Reinstall face plate.
You can even do this with the boat still in the water. My understanding is it doesn’t become more challenging until you use your last seal. Then the coupling has to be undone to install more (or just replace everything at that point.
I have done this. It can be easily done in the water--assuming everything goes smoothly. Check out this video:
However, in my case the screws had seen enough saltwater and age that the system would not disassemble easily. I essentially had to cut the entire system apart to get it off. No way to do that in the water. Yours look corrosion free and they have tweaked the design so that it is less likely to become impossible to disassemble. With that in mind I doubt you will have that problem but keep it in mind.
[-] The following 1 user Likes hiccup's post:
First_Light (03-10-2025)
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 350 08-18-2026, 02:11 PM
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 335 07-25-2026, 09:15 AM
Last Post: roboh20
  Freezer Replacement for 40' Tiara Reprise1 4 1,634 06-09-2026, 02:28 PM
Last Post: fuzzy
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,336 05-22-2026, 06:41 PM
  Tiara Express Battery Charger Replacement Svdb12@chartermi.net 0 609 09-07-2025, 11:19 AM
Dripless seal replacement. How much effort?00
