Coronet 2900 - Water in forward bilge
Hi
I have noticed some water in the forward bilge area which is accessed via the panel under the steps. Is this normal?
As there is no forward bilge pump does this water get pumped out by the mid bilge pump in the engine area?
Any help would be appreciated.
Water in the bilge is always a fun game.
I’d start with things where you know there’s water…shower dumps (is the pump failing?), shaft seals, and rudder ports. If those are all working properly, check things like faucets and fixtures. Finally, I’d look at leaks like from deck side fittings, windows, etc.
First, clean up the water. Does it come back? How fast? Next, look In every compartment for any “trails.” Takes some investigative work.
I had some mystery water up forward under my shower sump. Everything worked properly and I could find no leaks. Cleaned it up and discovered it only came back after like a weekend onboard. It became a real head-scratcher. In the end, the pump in my shower sump was failing. Just so happened it would be running when I would check it. Replaced the pump and water is gone.
Thanks for that.
I will empty it out and start to investigate.
No shower or a/c on boat so is either head or kitchen sink.
As there is no forward bilge pump, I would assume if it was to become a problem, there water would make its way to the mid bilge where the mid bilge pump would kick in??
Check your anchor.locker drain. I had an old boat (not Tiara) that would get clogged and run the water into the forward bilge.
My brother has the exact same issue on new to him same model. we had to suck it out with wet/dry vac. Not sure where the hell its coming from. I'll post if we find it.
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,360 05-12-2026, 10:18 AM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,566 02-23-2026, 11:01 AM
  Water alarm in the diesel filters maxcav 0 426 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 527 11-21-2025, 05:53 PM
Last Post: lenoah
  Keel bilge pump runs on 52 Sovran Salon during trips Knot On Call 9 2,540 08-21-2025, 08:28 PM
Coronet 2900 - Water in forward bilge00
