Zf 302v-ld trans prop shaft removal
Hello All,
I need to remove the prop shaft from the coupler on the transmission to replace the lip seals on my Norscot pack less. Has anyone down this before on a ZF 302V-LD? It’s in a 1995 3500 express with 6cta’ s.
Todd
Docked Wages
I've had it done by a boatyard. New PSS shaft seals installed. Not too bad a job.
You need the boat out of the water, remove couplings and propellers, pull shafts out (they clear rudder).
Check alignment on everything while this work is being done.
Coupling to shaft concentricity and propeller balance. Final engine alignment when boat is in water.
I have same transmissions, different boat - 4000 Express
Thanks Richard,
Trying to remove shaft from coupler but no room to get a jaw puller on it, it’s only about 4” from bulkhead and didn’t want to use a slide hammer on shaft. I’ve fabricated a tool that will put pressure on it and am going to use a slide hammer on shaft and hopefully she will pop out of coupler with just a couple hits- kinda worried about the trans drive shaft using slide hammer alone.
(02-19-2023, 08:31 AM)Docked Wages Wrote: Thanks Richard,
  Rubber Damper Failure between ZF trans and 3208's JonesE 6 1,545 08-06-2025, 05:38 PM
Last Post: JonesE
  Prop Size for 4300 Open with 3196 CAT's bnr@dur-a-flex.com 4 2,410 08-23-2024, 01:02 PM
Last Post: bnr@dur-a-flex.com
  35 open shaft log size J.klaffer 3 3,324 04-30-2022, 07:16 PM
  2006 Volvo D6-370 air filter removal gdynkowski 2 3,292 04-17-2021, 05:32 PM
Last Post: gdynkowski
  [Tiara Convertible] Muffler removal 36 PC with Cummins 6CTA8.3 Redmist 1 2,479 01-26-2020, 01:45 PM
Last Post: janste2018
Zf 302v-ld trans prop shaft removal00
