Threads: 2
Home Port: NC
Vessel Info: 1999 Tiara 4000 Express. Cummins 6CTA 450 HP engines.
Help,
My garage door closed and now will not open. Is there a way to manually raise the door? I think the fluid is low. The catch is that to access the hydraulics you must open the garage door.
Thanks,
John
Threads: 8
2
Home Port: Lake Superior
Vessel Info: 2001 40 Express
"My garage door closed and now will not open. Is there a way to manually raise the door? I think the fluid is low. The catch is that to access the hydraulics you must open the garage door."
Yessir. Open the round ports that are in the aft-facing settee & disconnect the pins that hold the hydraulic system to the door & you can open the door by hand.
Threads: 21
Home Port: Ohio River
Vessel Info: 2000 Tiara 3500 Express. Factory Hardtop. Cummins 6BT 5.9 Freshwater Only. Previous Boston Whaler Conquest.
We have a 3500 Express, I unbolted the top hinges and got the trunk open.
Mike
