Tiara Open Raw fuel smell while running
I have a 1992 Tiara 330 open with twin merc gas 454's. 2300 hrs. May be losing compression in #4-105psi #5-115psi & #6- 108psi that may be causing poor combustion. Just seems that the exhaust has too much of a gas smell. May check carb mixture screws but looking for any additional advice to clean it up.
I have been fighting that for years now. My brand new exhaust was sagging causing the fumes to get into the cabin and setting off my detector. Have that all fixed but still get it coming over the sides when fishing if the wind is blowing at me and sometimes when underway due to the vortex created behind the boat. I have installed new carbs, had them professionally tuned twice, installed K&N flame arrestors, HEI ignition and still does it. A few things that I have heard lately...May have to run a 10ga wire from ignition to HEIs. Make sure flame arrestors are clean. Plugs are good and gapped properly. I may just go with fuel injection. I heard around $2,500 a side.
Please let me know if you discover anything.
I would pull the plugs first and look for signs of a rich mixture. A stuck choke or bad float seats / levels could explain what you are experiencing.
I was getting a raw gas odor down below. I had a cracked filler hose.
  Upgrading to fuel injection Joeboch348 1 1,001 11-26-2025, 12:14 PM
  Fuel Filler Hose Joeboch348 1 708 08-18-2025, 04:24 AM
Last Post: Capt. Paul
  Engine shut off while running Mydiamond 1 711 08-10-2025, 07:51 PM
  [Tiara Open] 454 XLi Low voltage at electric fuel pump Mtgates44 3 1,733 04-27-2025, 10:19 AM
Last Post: Mtgates44
  Gas odor after running spoggy 2 1,921 09-14-2023, 04:56 PM
Raw fuel smell while running00
