Threads: 1
Vessel Info: 1988 36 Open Cat 3208 "375"
I've recently discovered water in salon bilge not coming from the shower pump any suggestions would be appreciated.
Threads: 22
5
Home Port: Stuart, FL
That's the best trick. Talc powder will show where it's coming from. It's trial and error. Capt. George
Threads: 14
2
I also found that the sink drains or water feeds to either the head or galley sink may be leaky. Both these feed into the mid salon bilge. Not a lot of water but some.
Good luck
Threads: 2
4
Home Port: Lake Michigan
Vessel Info: 2003 42 Open - Cat C12
Also check that the fittings on the fresh water tank are not cracked or loose... Do you notice it more after you fill fresh water etc? Is it worse when it rains etc?
Threads: 41
you may also want to check the ac line it could be broken and dripping into the bildge
