Fresh Water Tank Removal
I have a 1990 Open with the aluminum fresh water tank that is leaking quiet a bit from the welds. Just curious if anyone has removed one and how? I am really not wanting to cut through the floor to remove it.
I have the same problem. After much investigation I plumes the tank pump to the fresh water intake put a strainer and 3m .02 micron filter on and it works great. Can not drink the water but we never did. Cost about $300.
Sent from my SM-N910V using Tapatalk
[quote='tedemerick' pid='4738' dateline='1438279529']
[But you still can't have water at sea, right? I get fresh water from the dock through the freshwater inlet without any pump because my freshwater hose inlet bypasses the tank. If I fill up the water tank thru the tank fill, the water leaks out of the corroded holes once the pump puts pressure to it. Tiara CS mentioned using a plasma cutter to cut the tank out and install a new one, or cut an opening in the tank and install a bladder as options. Guess I'm going to give it some more thought and work on it as my winter project  ]
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 756 06-20-2026, 07:16 AM
  1997 4000 Express - Holding Tank Replacement jennyJ 9 4,747 05-26-2026, 07:27 AM
Last Post: frank.koetter
  Water tank level sensors Final Pursuit 4 2,195 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,103 09-17-2025, 05:52 AM
Last Post: Splendor
  Water quick connect fittings Final Pursuit 2 1,586 07-30-2025, 03:18 PM
Fresh Water Tank Removal00
