38 open
Purchased 38 open in July. 2003 which we love .winterizing for first time so I have many questions.how do you get to fresh water tank to drain.boat came with no zincs on tabs. I noticed corrosion on tabs and want to put zincs on which ones should I get.thx bill ps using my wife's address because I can not get online with my old email address
(11-06-2016, 07:01 PM)Susanwalter Wrote: [Only registered and activated users can see links Click here to register])
Thanks for info.i had a33 open before and would blow out system also.owners manual said to drain tank first but it seems impossible to get to tank.i did the pink stuff because I was concerned with the residual that pump didn't get.i agree the taste takes awhile to get rid of.i have Cummings 480 Che's in my boat.do you have Cummings and if so do you have preheat.bill wading River ny.
I also noted your post on leaking hatches.my are leaking from the seal between the acrylic and frame.I would like to change the acrylic when I rebed.where did you get acrylic for hatch.bill
Also do you do anything special to engine s. I ran anti freeze through and then drained muffler.seemed most of anti freeze came out shaft so I emptied muffler. Is this typical.
(11-07-2016, 10:04 AM)Susanwalter Wrote: Thanks for info.i had a33 open before and would blow out system also.owners manual said to drain tank first but it seems impossible to get to tank.i did the pink stuff because I was concerned with the residual that pump didn't get.i agree the taste takes awhile to get rid of.i have Cummings 480 Che's in my boat.do you have Cummings and if so do you have preheat.bill wading River ny.
I don't believe you have to empty the tank completely although if that makes you happy that's it.... The tank is Aluminum and with the little that may be left I look at it as a big ice cube tray.... Never had a problem although there is always a first time.....Agree it's impossible to drain completely....  My 2003 has 450 Diamond Series 6CTA Cummin's.... Great engines......Can't remember the last time I preheated the engines. They start easily, even after sitting the entire winter....
Not sure which post you read regarding leaking hatches but it's not mine.... My hatches are solid and don't leak at all.....
I stay in the water year round and get a short haul every 2 years to do the bottom and change zinc's (replace shaft zinc's during the summer of the 2nd season using tanks and going under the boat)... I change  engine oil/filters, fuel filters (Racor's/engine), and fresh water cooling filters that are on the engines every year before I lay it up for the winter. I also drain the mufflers and saltwater intake strainers after the engines are winterized w/non-tox antifreeze....
Looks like you live near me.. We boat out of the North Shore in Smithtown. Where do you keep/boat from?????
Yes we live in wading River and keep boat in Stirling harbor in greenport.im still getting use to this site so therefore my mistake on the hatch post. It was another person.i have many winter projects set up on boat so if you don't mind I will be pestering you because the boats are identical.
No problem and welcome as a Tiara owner. Know Greenport extremely well as we have stayed there many, many times.... Use to go to Townsend Manor but most recently (last 6-8 yrs) at Mitchell's Marina right in Greenport.....If I can be of more help, feel free to contract me...
bwoods94 (11-27-2016)
  2001 3500 open, diesel exhaust flanges? North Star 4 1,404 02-24-2026, 08:55 AM
Last Post: North Star
  1989 33' Tiara Open - Bedding Question jgaudet2 2 2,058 12-21-2025, 10:02 AM
Last Post: jgaudet2
  2003 3100 Open cabin privacy curtain. Hilary 3 2,726 12-02-2025, 02:13 PM
Last Post: E-MAN
  [Tiara Open] 2006 Tiara 42 Open Powered With QSM 11 675 hp - Thoughts ? DoctorM 5 3,882 10-20-2025, 09:05 AM
Last Post: DoctorM
  [Tiara Open] Tiara 3100 Open Randyracer1 6 9,814 09-18-2025, 09:58 AM
Last Post: REEL THERAPY
38 open00
