Threads: 14
Home Port: eastern long island
Vessel Info: 20003 Tiara 38 open
Would like to put underwater lights on over the winter.was thinking of the sea blaze x surface mount.anyone have any experience with these or. Have a better solution.the seablaze are about 320 a light.Bill
Threads: 14
I agree I hate drilling holes in my boat below the water line but if done right it should be like any other through hull.these lights only require a quarter inch hole for wire.haddent thought about growth but I'm usually swimming around boat with a brush and usually don't have much growth on transom.Bill
Threads: 22
5
Home Port: Stuart, FL
11-26-2016, 03:42 PM
(This post was last modified: 11-28-2016, 07:19 AM by Uhehner.)
Maybe Chris B would know. When you drill through the transom below the water line is it solid glass or will you hit a wood core? Capt. George
Threads: 1
Vessel Info: 42 Open - CAT C-12
The years ago I installed 4 sea blaze x's when they came out on my 42 Open and love them!
42 Open - C12 Cats
Threads: 14
Was thinking of putting 3 lights on my boat .is that enough for a 14 foot beam.did you go with the blue white lights.Bill
Threads: 9
4
Home Port: Daytona Beach, FL
Vessel Info: 2000 Tiara 3500 Open
Cummins 6bta -370
12-20-2016, 07:22 PM
(This post was last modified: 12-20-2016, 07:23 PM by trit21.
Edit Reason: Forgot to mention they are the X lights.
I installed 3 seablaze x blue/white/strobe lights on my 35 open, 13.5' beam. They provide plenty of light IMO, YMMV. You can inquire to Tiara if your hull below waterline is solid, mine is. Easy install. As far fouling, mine do not foul very much at all and a simple wipe and the fouling that is present comes right off.
Threads: 14
Thanks for the info .i did not see much about the install other then putting the lights on the hull and putting wires thru.did it come with any info on doing the electrical.was that something you did or did you have it done. Did it come with any of that or were you on your own.Bill
Threads: 14
Sounds good. I have some good wire for the job.was thinking of putting a bus block in back and run to my circuit breaker panel.i have a couple of openings there.i have these carling breakers that have square front that fits in my panel.what size circuit breaker did you put in.did the manufacturer recommended anything specific for 3 lights.Bill
