8.1 Crusader Raw Water Pumps
I'm having problems with the Raw Water Pumps on my 8.1 Crusaders 2001.They last about 3 years at best and then start leaking and spraying water all over the engines. This can cause major damage if not caught in time. The water then causes corrosion on the mixed metal (brass, steel, aluminum ) high pressure fuel pump (I replaced them) that corrodes through and sprays gasoline creating an explosion hazzard. These are Sherwood P110 pumps, about $400 plus labor, stainless steel with a cheap rubber seal that allows water into the bearings and it just gets worse from there. There is no support for the impeller end of shaft and my guess is that's the problem. The Sherwood pumps on my old 454's were over 10 years old and still not leaking. They had support on both ends of the shaft. I am now retrofitting the engines with the newer (2005 and up) pumps. Any comments or experience would be appreciated. Capt. George
I have a 3100 with 8.1's also. Same year 2001. Both of my pumps were updated to the newer style, I think 2003 and up in the parts catalog. Both were leaking.
Jeff
I do not have specific information on 8.1 Cruisader Pumps, but here is a tip I learned years ago.
Raw water pumps have weep holes to let you know when the pump seals fail. Vessels that sit for long periods of time can develope minor corrosion on the shaft up against the seal inside this weep hole. When you fire up the engine the corrosion chews at the edge of the seal. The more damage to the seal, the further inward of the seal the corrosion develops. Eventually the seal begins to leak.
Tip: Pump the weep holes full of synthetic silicone grease. The synthetic grease won't damage the seal and it keeps corrosion from developing on the pump shaft.
  '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL Showtime 3 2,044 05-23-2026, 02:12 PM
Last Post: Capt. Paul
  [Tiara Open] 2003, 3100 with Twin Crusader 8.1L MPI Gas Engines jmdegraff 2 1,481 06-16-2025, 08:07 AM
  1997 Crusader 454 XLi Service Manuals TiaraTom 4 4,977 01-16-2025, 08:59 AM
Last Post: dthelen40
  [Tiara Open] Crusader gas engine crank but no spark Mydiamond 1 2,798 10-18-2023, 04:32 AM
Last Post: czarcone
  Crusader 8.1 mpi surges at running speed Betterdays123 13 17,275 06-28-2023, 09:57 AM
Last Post: Phil Lane
Today 06:45 PM
» Replies: 5
Today 05:45 PM
Today 02:44 PM
» Replies: 8
Today 02:43 PM
Yesterday 08:09 PM
