I have to take off my prop,what size nut is on the 2" prop shaft of 2006 3600 sovran?
going to have to do this in the water, just checking if anyone knows .  I have 22x23x2 epx300 props, in case that helps.  TIA
(07-17-2017, 10:50 AM)sluggo Wrote: going to have to do this in the water, just checking if anyone knows .  I have 22x23x2 epx300 props, in case that helps.  TIA
It's not a fun job but here is how I did it. Pull the cotter pin.  Put a block of wood against the bottom of the boat to wedge the prop.
Use an adjustable wrench to loosen and remove the outer nut . Back off but do not remove the inner nut . Install the wheel puller
and use a BIG hammer to loosen the prop. Take off the nut and remove the prop. When reinstalling the prop, the thin nut goes on
first. Google the reason on the net.
DO NOT do this at a marina where there is electric on the dock. You could be electrocuted. Heed my caution.
Thanks!! do you know what size nut is on the shaft??
Check with a prop shop that straightens shafts.
sluggo (07-24-2017)
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 390 08-31-2026, 10:34 AM
Last Post: Herrema4
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 559 08-17-2026, 05:31 PM
Last Post: Bford100
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 387 07-28-2026, 06:28 AM
Last Post: Tiara45
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,434 05-22-2026, 06:41 PM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,674 02-23-2026, 11:01 AM
I have to take off my prop,what size nut is on the 2" prop shaft of 2006 3600 sovran?00
