Seacock valve for holding tank
We own a 2002 3800. I went to go do an overboard pump out on my holding tank and the handle on the seacock (Y valve) snapped off.
Can I just replace the handle and be good to go or do I need to replace the whole valve. How would I do that if the tank is half full?
Thanks,
Pbud
Assuming you are talking about the y valve and not the thru-hull sea cock? If so You can try to replace the handle on the y valve and if unsuccessful, go to a marina and have the tank pumped out a couple times with fresh water flushing. Then get a bucket under the valve as residual waste will leak out when you pull the hoses. Probably should wear gloves, mask and eye protection. Good time to replace any stinky/permeated hoses too.
I had the same thing happen to my Bosworth brand Y-valve.  Unfortunately the whole valve needed to be replaced as a result.  Rinse a lot of fresh water through the system including down the tank discharge before you dismantle the current valve.  In the future, consider using a small amount of vegetable oil on occasion to lubricate the Y-valve.  I dribbled the oil down the tank discharge.
(08-13-2017, 11:41 PM)pbud Wrote: We own a 2002 3800. I went to go do an overboard pump out on my holding tank and the handle on the seacock (Y valve) snapped off.
Thanks,
Pbud
I have had multiple valve handle failures on my boat. It's an '88. In each case the steel handle on the original valve rusted and weakened. Trying to find a replacement handle that fits was impossible. I replaced the whole valve with West Marine valves with heavy stainless steel handles and the problem was solved.
You could try opening the overboard valve using a vise grip pliers for a handle. Then flush the tank and replace the whole valve.
Keep a short piece of PVC pipe on board to give you added leverage when cycling the valves. This should be part of your yearly maintenance.
  1997 4000 Express - Holding Tank Replacement jennyJ 9 5,105 05-26-2026, 07:27 AM
Last Post: frank.koetter
  Water tank level sensors Final Pursuit 4 2,395 10-09-2025, 06:37 AM
  Holding tank collapsing fix giff1 5 3,146 10-18-2024, 06:00 AM
Last Post: egstasea
  2018 38LS Black water tank location Scottbee 1 1,804 03-11-2024, 10:27 PM
Last Post: Scottbee
  2013 5800 Sovran shower valve Lteneleven 1 2,595 01-08-2023, 02:14 PM
Last Post: bwise
