33 OPEN WINDSHIELD CENTER VENT
My center vent window on my windshield has black gasketing (or seal) all around. especially at the bottom.
This material has dried out through the years. Does anyone know what the replacement part is? or remedy?
Thank you.
(03-31-2015, 09:25 AM)stones throw Wrote: My center vent window on my windshield has black gasketing (or seal) all around. especially at the bottom.
Thank you.
Tiara HQ can hook you up.  Ordered one last month for a 97 31 Open.  Just over $100.00 delivered.  Receipt and materials are on the boat so I don't have more detailed info handy at the moment...
[-] The following 1 user Likes Harwood's post:
YOLO (04-05-2015)
Just actually finished mine up today. Got the weather stripping from Tiara. you will need 18ft of 542211 and 9ft of 529092. The 529092 is flat and goes on the window frame. The 542211 goes on the window.  I took the window out by disconnecting the power opener and lifting the window from the outside, up pretty high and working it out. make sure you take note of how high you have to lift it because that is the only height that will allow you to put it back in. Doing this is not real easy in or out. Ive done it a few times. Strip off all the old stuff. I then taped and repainted the window. There are 2 rows on the port, starboard and bottom of the window.  Tiara also has a pdf drawing labeled Sash Gasket Drawing pdf. I strongly advise you to get it from them because the 542211 weatherstrip goes on differently then you might think. If they don't have it, I do, I can e-mail you a copy. Make sure to miter the corners especially at the bottom. These lengths are for my 33 open don't know if other models are different
Kurt
[-] The following 2 users Like kurts52's post:
erikfrasco (09-24-2023), YOLO (04-05-2015)
Hey, Kurt,
Good info here.  I just looked at mine yesterday.  The L shaped Gasketing - as you  suggested - does not go on the way you would think it would.  I have the materials in hand, but I do not have the .pdf you reference.  I'll call Tiara, but if you could shoot me a copy that would be great!  EMail:  toobusy2play@juno.com.
BTW, the lengths you specified are the same as Tiara sold me...for the 31 Open...
Thanks!
  38 open bathroom recessed light bulb twilson0929 3 121 4 hours ago
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 268 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 598 07-07-2026, 08:13 AM
  Windshield Wiper Arms and Blades Lafobrian@gmail.com 17 15,250 06-20-2026, 11:59 AM
Last Post: nylakeshome
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,244 05-22-2026, 06:41 PM
33 OPEN WINDSHIELD CENTER VENT00
