31 open
Port engine overheated and by the time the temp gauge and alarms went off the antifreeze was cooked. Thoughts as to cause, strainers don't appear blocked and seems drastic for a thermostat
Water pump Impeller, Elbows if they are over 5 years old, Heat Exchanger if it has never been cleaned.
Start with the easiest things, the water pump and the thermostat. Install a new impeller and replace the thermostat.
Also check the oil heat exchanger. Pieces of the water pump blades break off and block the flow here. Pull off the hoses and back flush it.
Put a heat gun on the elbows and check against the good engine.
That should keep you busy for next weekend.
Capt. George
Capt. George has it right.
I had the same problem, turned out to be a cascade of broken Alternator belt putting pressure on the water pump that went next and overheated the engine.  Fortunately i was just out of the harbor and limped back.  talking to the mechanic, the balance on both belts is related and if one goes the other will almost certainly.
Had to flush everything to get the broken impeller blades out after we replaced the water pump.
Good reminder to check belts and impellers at least yearly, if not more!
  2001 38’ Open interior table base removal twilson0929 3 908 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,530 05-22-2026, 06:41 PM
3500 Open deck lift piston
Last Post: drmiagi11
Today 12:51 PM
» Replies: 3
11-04-2026 11:36 AM
