Threads: 1
0
Home Port: Staten Island, NY
Vessel Info: 2005 Tiara 29' Classic
Twin Volvo D4
My air horn stopped working. I checked all on my manuals and can't locate where it is. My guess is that it is between the helm and the AC / DC panel below deck.
Also, I am guessing that there is an air compressor involved.
Any info is appreciated.
Thank you.
Threads: 14
11
Home Port: Kings Park, NY
On my 2003 38 open the compressor is located behind steering station (tilt the helm station) and then behind a screw out deck plate on the starboard side of the inner hull liner. Not sure if yours is in the same place
Threads: 22
5
Home Port: Stuart, FL
If it's an electric horn, look under the gunnels. Capt. George
Threads: 11
0
Home Port: Lake St Clair
Vessel Info: 1997 33 Open with 6b 5.9 Cummins diesels
On my 33 open the compressor is located behind the 6in screw in cover on the starboard panel at the helm. I suggest taking off the connections at the compressor (should be fairly easy to pull off) and putting a meter across the terminals. Should have 12volts there when you activate the switch.
Kurt
