3900 Sovran Headliner in Salon
Does anyone have a recommended repair technique for sagging vinyl headliner in salon? There seems to be wood above, and it looks like velcro was used to hold it, but it comes down especially while underway. In a few spots, I tried sliding in heavy duty velcro, but it doesn't seem to stick to the wood. All of it is in perfect condition, just seems to be "saggy" Thanks.
On our open, I had to basically remove the panels and apply new velcro using both the adhesive on the back as well as reinforce it with a staple gun... I had good luck with the stiff locking velcro instead of the fuzzy stuff... If you need to build it up a little underneath, you can place a piece sticky side to sticky side in the middle.
max
(06-27-2017, 08:46 AM)Maxwell Wrote: On our open, I had to basically remove the panels and apply new velcro using both the adhesive on the back as well as reinforce it with a staple gun...  I had good luck with the stiff locking velcro instead of the fuzzy stuff...  If you need to build it up a little underneath, you can place a piece sticky side to sticky side in the middle.
max
Thanks Max. I'll take a panel down and try. Didn't want to undo something before I knew how I was replacing it. might try a little gorilla glue on back of adhesive velcro that goes against wood, too. happy boating. t
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 517 08-31-2026, 10:34 AM
Last Post: Herrema4
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 662 08-17-2026, 05:31 PM
Last Post: Bford100
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 474 07-28-2026, 06:28 AM
Last Post: Tiara45
  Removing Wall Panel on other side of helm on Sovran 3500 no shocks 1 1,110 02-15-2026, 03:38 PM
  Keel bilge pump runs on 52 Sovran Salon during trips Knot On Call 9 2,954 08-21-2025, 08:28 PM
3500 Open deck lift piston
Last Post: drmiagi11
Today 12:51 PM
» Replies: 3
11-04-2026 11:36 AM
