Tiara Open Crusader 454 XLI : Just cut out
Running 1996 Tiara 29 Open with Crusader 454 XLI's. Went out today and after about 10 mins. starboard engine cut out, just under crusing speed. Won't restart, cranks but no start. Put a spare cap and rotor on, no help. One thing I noticed is was when I turn the key to start there is no Beep Beep and the alt red indicator doesn't light. Any thoughts. Thanks
Ignition relay Part # 98175 I believe. Should be located in a black box on the starboard side of each motor, near the front.  Black box should have a couple red circuit breaker reset buttons visible on the exterior.  Open the box and there are a couple relays in there.  Ignition relay costs approximately $25, buy two.  I replaced four of these relays over the course of ten years.  If you are in a pinch and cannot locate the Crusader part quickly, I believe the same part was used as a turn signal flash unit on Pontiac automobiles.  Bob
Thank you RMS, I know the box, I have had to reset them 2 or 3 times in the last 14 years, but never looked inside. None of them were tripped when I checked. I'll check it out, so they can go bad?
Yes, the relays go bad and without any warning.  Bob
Thank you RMS, Changed out the ignition relay and it started right up. I now carry a spare. Bob
  [Tiara Open] 2003, 3100 with Twin Crusader 8.1L MPI Gas Engines jmdegraff 2 1,518 06-16-2025, 08:07 AM
  1997 Crusader 454 XLi Service Manuals TiaraTom 4 4,988 01-16-2025, 08:59 AM
Last Post: dthelen40
  [Tiara Open] Crusader gas engine crank but no spark Mydiamond 1 2,813 10-18-2023, 04:32 AM
Last Post: czarcone
  Crusader 8.1 mpi surges at running speed Betterdays123 13 17,316 06-28-2023, 09:57 AM
Last Post: Phil Lane
  Crusader Mechanic Needed North Florida 904polarized 1 1,951 03-27-2023, 04:41 AM
Last Post: 904polarized
Yesterday 11:36 AM
89 3100 convertable
10-30-2026 06:13 PM
