Author's Statistic:
Threads: 1
Likes Given: 0
Likes Received: 0 in 0 posts
Home Port: Key Colony Beach,
Vessel Info: 2006 Tiara 2900 open classic with twin volvo d4 diesels
Author's Statistic
Threads: 1
Likes Given: 0
What bildge pump should I get to replace the Attwood 2000 model 4060 heavy duty?
Author's Statistic:
Threads: 22
Likes Given: 1
Likes Received: 25 in 24 posts
Home Port: Stuart, FL
Author's Statistic
Threads: 22
Likes Given: 1
The determining factors are the "Gallons per Hour", voltage and hose size. Try West Marine, Rule makes all size pumps. If you put an Attwood back in the mounting bracket will fit without modifications.
Author's Statistic:
Threads: 8
Likes Given: 0
Likes Received: 7 in 6 posts
Home Port: Catawba Island, Ohio
Vessel Info: 36 Sovran
2006
Cummins QSC 490h
Author's Statistic
Threads: 8
Likes Given: 0
2006
Cummins QSC 490h
I also need to replace a bilge pump and cannot find a Attwood 4060. Were you able to find a replacement that fit the custom bracket by Tiara.
John
36 Sovran, Cummins QSC
