Author's Statistic:
Threads: 25
Likes Given: 0
Likes Received: 1 in 1 posts
Home Port: Punta Gorda, Florida
Vessel Info: Looking to purchase a 3100 Open
Live in SW Florida
Threads: 25
Likes Given: 0
Live in SW Florida
Both of the impellers on my 2000, 3100 Open , have failed. Within days. Did not ground. What on earth could have caused this?
Could it be a failure in my flush out system? Water draining from the raw water intakes when I put the boat on the lift? I never run the engine dry.
Author's Statistic:
Threads: 3
Likes Given: 2
Home Port: North Point Marina; Lake Michigan
Vessel Info: 2006 Sovran 3600 with Cummins QSC 8.3 490 hp
Threads: 3
Likes Given: 2
Impeller are a wearable item and should be changed regularly. I keep a spare set on the boat at all times
Since both engines usually are run about the same I always figure that if something goes bad on one the other is not far behind. I always buy 2 of everything and figure I will be using the other one fairly quickly.
(05-07-2019, 07:05 AM)Coppifan Wrote: Both of the impellers on my 2000, 3100 Open , have failed. Within days. Did not ground. What on earth could have caused this?
Coppifan@aol.com
Make sure you (or your mechanic) locates all the pieces! They can (and will) clog cooling passages.
Coppifan@aol.com
It takes a couple of seconds of dry running after you’ve been on the lift for water to run through the pump and start lubricating it.
Next time open the impeller cover and prelubricate the impeller. Liberal application of dishwashing liquid is how I do it. Use the opportunity to inspect your impeller!
