i store the boat indoors for the winter, this year when i opened up all the hatches in my floor i noticed about 2 inches of water in the forward bildge, basically under the floor in my bedroom, there wasnt any last winter, i did have the marina wash the boat down and scrub the hull this year wich i did not have them do last year, it was out of the water when they did this, could that be where the water is coming from? going over there today to suck the water out with a shop vac, thats the only thing i did different from last year, does this make sense? also maybee the boat isnt level on the blocks its sitting on so maybee all the water is coming to the front of boat? thanks guys...
My 43 Open had closed bulkheads so water (or fuel) can't make it from the keel forward. Not sure about the 42 and it may be a good question for Tiara. If you have open bulkheads then yes if the boat is blocked with forward pitch then water would migrate under the salon or stateroom. If closed bulkhead possibilities include leaking / non working shower sump, AC condensate drains venting direct to bilge (these are usually plumbed into shower sump), leak in the fresh water system (including ice maker) or a drain line, leaking FW pump or compromised water tank. Maybe some other owners have suggestions but that's where I would start. good luck
I have a 41 Open and have experienced the same thing (the 42 is a massaged 41). I do not think the bulk heads are closed on the 41. Sometimes there is water forward, sometimes there isn't. I contributed it to many factors including fuel load, bow pitch in storage (boat sits flatter in storage than when in the water) and even the acceleration and braking of the tow when they trailer it to storage. I can't stand a dirty bilge so I'm down there with a shop vac too.
