Microwave Replacement
My 2002 38 Open has an Emerson MW8102SS microwave oven, an obsolete model, that is kaput. What else will fit in the hole? It is slightly wider than the Emersons from Walmart and Amazon.
Instead of replacing with another microwave I am considering using a convection/microwave oen but am having a similar problem getting one that fits exactly
I had a similar problem on my last motor home. A side opening door has two switches. One controls the fan, lights, controls and the other one controls the magnetron. When the two switches are not triggered at exactly the same time it assumes you have opened the door with the magnetron still operating. In my case works for a couple of minutes and apparently the heat generated is causing the magnetron switch to turn it off. Everything else is still working but it is no longer cooking. After cooling for a few minutes you can get a couple more minutes of cooking. With these cheap microwaves the problem can also be caused by pulling down on the door when you open it causing the door to warp, thus throwing the synchronization off.
I found the size in my manual and am  going to try and find a replacement. I also would like a combo but I think most are bigger.
Surely no one in their right mind would hard wire a microwave????
The old is out and it was not hardwired. The box is at the top left. It screws down on the black board pictured with the legs sitting in holes. This board is secured to the boat by two screws on the front that are exposed with the door open.
Going shopping at Best Buy today. They have several that are fractionally smaller than the Emerson. GE or LG looks the closest. I could not find a combo convection unit that would fit.
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 463 08-18-2026, 02:11 PM
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 429 07-25-2026, 09:15 AM
Last Post: roboh20
  Freezer Replacement for 40' Tiara Reprise1 4 1,872 06-09-2026, 02:28 PM
Last Post: fuzzy
  Tiara Express Battery Charger Replacement Svdb12@chartermi.net 0 704 09-07-2025, 11:19 AM
  [Tiara Sovran] Shore Power Cable Replacement wwaseleski1953 2 1,370 06-12-2025, 07:50 AM
Last Post: gracewilson
Yesterday 06:45 PM
» Replies: 5
89 3100 convertable
Yesterday 05:45 PM
38 - 43' Tiara Open Comparision
Last Post: tk17
Yesterday 02:44 PM
» Replies: 8
Yesterday 02:43 PM
Main DC Breaker for 1995 Tiara 36 Open
10-26-2026 08:09 PM
» Replies: 3
