Tiara Open Using Shore power for battery charger
My 2005 3600 Open is on land for the winter and i am trying to get power to my battery charger.  I have 2 30 amp connections on the boat.  I thought that if I connected the inputs to the 30amp on the boat to extension cord connected to a nearby outlet, that i would get power to the battery charger.  No luck so far. Batteries turned on, breakers on, am I missing something?  or is there just not enough power from a 15amp outlet to run the battery charger.  As you can tell, I'm far from an expert in this area...
Something is not “on.” I can run dual chargers on 8 batteries off my single 30 amp cord with extension cord adapter, so surely you should have enough. Is there power at the pulpit?
i'll have to check that out tomorrow.  thanks for reply
i discovered this weekend that the problem was a bad extension cord.  I have one more question if someone would be kind enough to reply.  Should i keep the battery chargers on all winter?  or should i just run them for a period of time each month?  thank you
Mine get plugged in once a month to top off the batteries. Stored indoors in an unheated building in NE Ohio.
Same here. About once a month for half a day or so. Leaving the boat plugged in and chargers on all winter would be a fire hazard. Most marinas won’t let you keep it plugged in.
That makes sense.  Thank you
I just bought an adapter and plug in once a month for a few hours to let the onboard charger do its thing. Boat is on the hard at the marina and there is a plug right behind the boat. I used to run a generator that was in the back of my truck for an hour but so much easier with the adapter.
The days of winter storage are over for me.
We’re three weeks out and champing at the bit!!
  Battery - leave in or remove for winter? Lobsta 6 4,851 10-26-2021, 06:50 AM
Last Post: Lobsta
  Battery Banks firstlight 3 4,557 06-11-2018, 08:01 PM
Last Post: rcwiegand
  Charger/Inverter Jakes 2 4,433 12-02-2014, 04:55 PM
Last Post: Chris Burkard
Yesterday 11:36 AM
89 3100 convertable
10-30-2026 06:13 PM
