Replacement Fridge for 1995 Tiara 3300 Open
Has anyone found a replacement fridge that fits the existing space and wiring schematic to replace a Norcold DE 704 (Operates on 110V or 12V.)
What is the size of the opening
I’m guessing the size/dimensions of the refrigerator — but I guess the question is what replacement fridge matches the specs/ dimensions?
I have a set of specs from Dometic but I'll be damned if I can figure out how to put them in a post
The are an odd ball size
Just replaced my Norcold fridge on my 99 3500 express.  Replacement is DE 0041.  Fits perfect in the opening, however the wood panel needs to be sized down.  Easily cut with a razor blade.  Getting in the boat is a totally different challenge.  I had to remove the cabin sliding hatch and all trim.  Not as bad as it sounds.  Remove door on fridge.  Then had to remove four screws holding the compressor on and very slowly and carefully bend the soft copper tubing so the compressor would sit on top of the fridge.  Secured it with a zip tie and string.  It fit through with the tightest of tolerance.  Set aside two hours.
(08-31-2022, 12:57 PM)Craig Dunlop Wrote: Just replaced my Norcold fridge on my 99 3500 express.  Replacement is DE 0041.  Fits perfect in the opening, however the wood panel needs to be sized down.  Easily cut with a razor blade.  Getting in the boat is a totally different challenge.  I had to remove the cabin sliding hatch and all trim.  Not as bad as it sounds.  Remove door on fridge.  Then had to remove four screws holding the compressor on and very slowly and carefully bend the soft copper tubing so the compressor would sit on top of the fridge.  Secured it with a zip tie and string.  It fit through with the tightest of tolerance.  Set aside two hours.
Thanks for all the detail and instruction. I had a feeling that cabin door would have to come off. I replaced the rollers on the bottom of the door a few years ago so know that drill already. I’ll give it a shot.
  38 open bathroom recessed light bulb twilson0929 3 440 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 353 08-18-2026, 02:11 PM
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 476 08-17-2026, 05:31 PM
Last Post: Bford100
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 336 07-25-2026, 09:15 AM
Last Post: roboh20
  2001 38’ Open interior table base removal twilson0929 3 712 07-07-2026, 08:13 AM
Replacement Fridge for 1995 Tiara 3300 Open00
