Threads: 10
0
Home Port: Vero Beach, FL
Vessel Info: 2008 3900 Sovran
My salon a/c is showing HPF code, all other units working fine. I’ve cleaned the sea strainer, but the problem continues…any ideas?
Threads: 10
0
I should have mentioned, it’s a 2008 3900 Sovran
Threads: 9
2
Home Port: Longboat Key, FL
Vessel Info: 2020 53 Fly
CAT 12.9-1000 Straight Shaft
(11-01-2022, 02:48 PM)Bdouglass Wrote: My salon a/c is showing HPF code, all other units working fine. I’ve cleaned the sea strainer, but the problem continues…any ideas?
Can also be inadequate airflow to unit. Be sure your air filter is clean and run fan on High instead of auto to see if error clears. If this also fails, likely need to clean water cooling system lines with barnacle buster of similar product. If this fails, time for a professional tech.
2020 53 Fly
Gulf Coast Florida
