43 OPEN with 660 hp CAT's - best prop?
Anyone have any advice on the best prop to use for a 43 OPEN with CAT 3196's making 660 hp.  I have to replace my set and was wondering if there is any new technology versus the traditional 3 blade prop that I am using now.
Current prop on boat is Federal Equi-Poise Cup 27x36.  I hit 2330 rpm's WOT at around 33 knots.
I would say you are propped correctly.  2330 is what the 3196s should see at WOT.
2020 53 Fly
Gulf Coast Florida
The Acme 4 blade should give you a little stern lift and a little better speed across the rpm range. They are an expensive set of wheels but if cost is no object then take a look and more importantly, see if you can borrow a set to see how your boat performs. 2320-2350 is what you want to see at full engine load and gross vessel weight.
Thank you for the information. Did you switch from 3 blade to 4 blades and experience the increase in performance?
I did not change out the props on my 43 but another 43 open maintained by the same yard put them on and reported well over a 2 knot speed increase, smoother operation and better handling. If you are serious send me a PM and I’ll try to connect you with the owner who has first hand knowledge.
pm sent thanks
  Looking for a 2006 or newer 32 Open Matta0413 3 1,302 02-04-2024, 10:58 AM
Last Post: Matta0413
  [Tiara Open] 3800 Open Fresh Water Tank Mineral Deposits twilson0929 6 579 12-12-2023, 03:52 PM
  TV 36' Open firstlight 4 1,369 10-24-2023, 07:49 AM
Last Post: Tkey
  [Tiara Open] Anyone have any plus or minuses about a1986 to a 1996 3600 Open Gpersi 5 1,332 06-15-2023, 09:03 PM
Last Post: Gpersi
  [Tiara Open] Repower an '84 3100 open with V6 or V8 diesels SaKiawa 3 2,829 06-11-2023, 06:02 PM
Last Post: Mikelaw
43 OPEN with 660 hp CAT's - best prop?00
