2006 3600 Sovran
Just brought this boat home 5 days ago. So much to learn. I wanted to pull the fiberglass helm panel forward. I saw the hinges at the bottom. At the top on each side there is a recessed area with 3/8’ nylock nuts.i thought those were supposed to be removed, however they just spin along with the bolt or stud. Thinking I’m not doing this correctly. Is there another method? What am I doing wrong? All help appreciated.
   Mike in Michigan
I made the same mistake. I believe those nylock nuts hold a rubber socket that sits on the inside of the dash. There is a plug mounted to the other side and when mated, keeps the dash locked in place. There should be a grab handle or two on the dash. Give it a good solid tug and the dash will swing open on the hinges.
Yup, just give it a strong pull and it should pop loose. I don't like those rubber sockets as they are often either too stiff (hard to open) or too loose (pop open in a sea).
Thanks- it took two of us but it did open up.
Music Tiara 44 Sovran Amplifier tburling1958 3 3,146 04-01-2022, 10:05 PM
Last Post: Folkvord
  2008 sovran 3900 Steering Hub / Drive by Wire VPelliccia 1 2,199 03-20-2022, 06:53 PM
Last Post: f02eric
  Tiara 3600 generator start up procedure Jsvending 2 3,169 04-08-2021, 12:24 PM
Last Post: Donaldjames
  2006 3Sovran 3600 cabin stereo issues sluggo 2 3,012 08-24-2020, 08:58 AM
Last Post: sluggo
  [Tiara Open] Cockpit Refrigerator 2005 3600 Open glc203 0 1,730 09-10-2019, 01:54 PM
Last Post: glc203
2006 3600 Sovran00
