Threads: 1
0
Home Port: Punta Gorda Isles, FL
Vessel Info: 1993 Tiara 2900 Open
2008 Crusader Classic 5.7
Here's an easy one, before I go crawling all over the boat can someone direct me to the location of the wiper washer fluid reservoir on a 1993 2900 Open? My assumption is somewhere in the motor room toward the bow. Not much room there and it would be nice to know where I am headed.
Threads: 14
11
Home Port: Kings Park, NY
Not sure if there is a separate water bottle for the washers on the 29 as the 31 Open and 38 Open get there water from the main internal fresh water tank.... The switch on the dash, marked "windshield washer", activates a solenoid in the engine room. On the 38 (& the 31) it's located on the forward starboard side of the engine room bulkhead.. M2C
Threads: 0
0
My '94 29 works the way ReelMagic described. It's plumbed to the fresh water tank.
The solenoid is in the compartment behind and under the swing up backrest for the cabin table.
Mark - Reely Nauti
Threads: 1
0
Vessel Info: 42 Open - CAT C-12
Any ideas where this pump is on my 42 open?
42 Open - C12 Cats
Threads: 1
0
I have a 42 Open with second stateroom. The pumps are located under floor just inside the doorway of that stateroom. There is small storage there also.
Threads: 1
0
Thanks all. No action on mine. I will check the solenoid. I get the feeling this board will be invaluable.
Thanks again.
