Boat carpet
Any suggestions for good site to find reasonably priced replacement carpet for my 29 open?
Cockpit or Cabin?
I replaced the cabin carpet myself. I bought a good quality indoor/outdoor carpet.
I carefully removed the old carpet and used it as a template. I cut it and glued it back in. It was pretty easy with the exception of removing the stairs.
The only problem I had was after I was done, I found my carpet was wet. I traced this to a hole in the hull!!
When I removed the carpet from under the table, the top edge was screwed to the hull in several places. It looked like the screw holes were pre-drilled and one was through the hull. It was patched with gel-coat and when I removed the screw it popped the patch.
Luckily it was about 2" above the water line. A little thickend expoxy fixed the problem.
My 2900 Open has very little carpet in the cabin as it's mostly a teak floor, so I'm not sure if you mean cabin or cockpit carpet... But if you mean cockpit carpet let me say I just received new "sisal" (inorganic) upper cockpit carpet from Tiara that I ordered after seeing the new Coronet, and it looks pretty awesome. I didn't even use my cockpit carpet before as I am not a fan of carpeting in general, but this is a completely different thing in my opinion, it really adds a lot to the look of the boat, looks far better than any real carpet, and can even be hosed off for cleaning.
  Good Boat Yard in SE Michigan for Repairs? MichFan 2 2,217 08-16-2022, 10:19 AM
Last Post: d5dekeyser
  Insurance for Florida Boat GeoDoc 2 2,410 06-11-2021, 12:10 PM
Last Post: Gosseligbeg
  boat horn honest mark 6 5,875 03-08-2021, 06:11 PM
Last Post: honest mark
  Anodes on transom of boat 2 sizes? Donaldjames 8 7,945 12-10-2020, 08:02 AM
Last Post: Misdirection
  How to sell a broken boat? Coppifan 4 5,824 08-12-2019, 07:45 AM
Last Post: johnhesch
