ground wire alert
I have a 2006 Sovran 3600.  Up on the electrical panel next to meters are 3 little lights, that indicated different problems with the shore power.  The second light keeps coming on, it says like , 'ground wrong' and the alarm beeps.  I have my power cords hard wired to the box on the one end, and the regular connectors on the boat end.  When the alarm goes off, I just reset set the breakers at the power box and everything reads okay.  My question is, what causes the alarm to go off??  I am sure I have things wired correctly, and when everything is reset, everything reads correctly, plus there are times, maybe weeks,  the alarm wont go off at all.   I thought for a while, a loose connection may cause this, and that's why I hard wired them to the box.  Any other thoughts???  TIA
  **CAUTION** HIGH WATER ALERT FAILURE - POSSIBLE FIRE SITUATION** Lobsta 1 842 04-26-2025, 08:38 AM
Last Post: Lobsta
  [Tiara Open] IMT Alert rotellats@gmail.com 1 1,210 08-18-2024, 07:44 PM
  [Tiara Open] Ground wiring waycamp 4 4,138 07-14-2022, 09:09 AM
  High Water Bilge Alert johnsbr321@gmail.com 4 7,397 11-03-2021, 10:19 AM
Last Post: decamagum
  wire diagram justrollin 2 4,167 06-04-2014, 08:36 AM
Last Post: Uhehner
