2001 31' Open hot water tank
My T&P relief valve is leaking and probably needs to be replaced. Does anyone know the temp and pressure threshold specs for the valve
Depends on your brand of water heater. Just Google "marine hot water tank parts" and go to the Defender site. They have a large selection with specs, depending on the brand. Typically 190-210 F and 75, 100, 150 PSI.
As a suggestion, NEVER flip the lever to flush the valve as some recommend. If you do, plan on replacing the valve, it will leak. Never had one that did not leak afterwards.
Capt. George
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 969 06-20-2026, 07:16 AM
  1997 4000 Express - Holding Tank Replacement jennyJ 9 5,360 05-26-2026, 07:27 AM
Last Post: frank.koetter
  2001 3500 tiera exspress Bucky 3 887 05-19-2026, 03:20 PM
  Water tank level sensors Final Pursuit 4 2,570 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,361 09-17-2025, 05:52 AM
Last Post: Splendor
